So, I have recently started my first endeavor in into custom framework coding.
So far the top features are:
Totally Event Driven
Does not require routing
100% PSR compliant
Supports "Mods"
Supports "themes"
Supports Multiple RDBMS SQLite, MySQL, MariaDb, Postgre, Oracle just to name the major ones.
Supports composer deployment
Will expose a cli command suite to ease development
Fine grained per object ACL
I'll update the thread as development continues and may actually do a few writeups on it. Might help others sharpen their skillz or pick up a few new ones.
