There are many advantages. What do you think they are? Myself, I don't think free software is as bad as it seems, seeing that the theme on a free one can be very attractive, despite the free software it uses.
Anyway, obviously, free software has limitations, and there often aren't free extensions to help and if you want someone to custom build one, then I'm thinking it would be expensive, but I can't blame the developer.
