Do you add holiday themes and features to your forums? Do you like them on other forums? An example would be a Christmas theme and snow could be a feature of it.
I don't tend to use them, personally, but I like them just fine and enjoy when others do.
They are ok however I've spent hundreds of dollars on holiday themes and apps with really no benefit so I've stopped using them.
On Christianity Haven, the owner put up the holiday themes add on and the members really are quick to gripe about it. They're not fans.
That's unfortunate, they should just have fun with it for a bit.
Most people don't like change, as you know many get used to changes and grow to like them. :)
It's been a year or two now, and they still complain.
  • 2 weeks later...
Oh well, to bad for them I say.;)
I was going to add above that many theme makers that do holiday ones disappear as well, making it very difficult to keep updated; I've only found one that's been around for a few years now that does them.;)
  • 3 weeks later...
  • 2 weeks later...
I think I found the correct Thems for the sites that I have, so there is nothing to change; now that I have my hand in some designing, I'll tinker with logos and stuff.
Eager to see what you have for the next event 🏆
