Completed Banner for mindsConnected new skin (2 Viewers)
This prefix indicates that the design request has been successfully completed and delivered.
Hi there @Bryn
Apologies for the delay I had not been well.
Please see attached the banners including logo source file. Let me know if you need anything adjusted.
I look forward to hearing from you!
Kind regards,
@Bryn: These look awesome, but how are they supposed to work out on a skin that can toggle colors?
Suppose @BRANSOL can provide a transparent version of it? Yeah, that could solve it but no way can the "minds" part can interact with the feature though... not unless I can change the colours myself for separate versions of it...
Yes, a transparent background would be best. The color generator I use does not affect the color of images at all.
In that case, I would code the header. Or just not have the color change possible and stick with the default color?
Blue on let's say, the color yellow would probably look ugly.
Especially not according to this.
And @Cedric, that would be nice for you to do but you have two options... either you PM me the code or I PM you the link to the test board, so that you can sign up and from then I can make you an Assistant (so that you can add it in yourself via the Admin CP).
Hey Bryn -- sure how can I assist? Which element you need transparent? The logo?
Let me know ill get that over to you right away!
