- Thread Author
- #1
My boyfriend has started his own small business and he has gotten the premium version of Wix to create his website. My boyfriend is pretty technical and alright with code but he is finding trouble on how to build a box build planner with drag-and-drop layers & PDF cart integration.
Can someone help me (and my boyfriend) with the code or how I would go about creating a box build planner that functions by dragging and dropping images onto a grid. The grid will have a cup layer, a lid layer, and an edge feature layer so the images can be on top of each other. There will be check boxes to turn off or on the layer visibility so the images in that layer disappear and reappear. There will be a border around the grid to define the grid working space.
The images are different sizes to represent the different physical sizes that are available in the store. It creates a list from the images and the quantity of images which can be added to the cart by pressing a button.
The button should also print each layer in the grid and the list to a pdf file that is included in the cart for reference. The list will be on the right side of the grid and will be displayed with the following columns with data pulled from the products. Name, sku, price and qty.
Any help would be extremely helpful thank you!! I've also created a thread on the Wix Studio forum to see if I can find the answer thanks.
