To write code that's is so easy to read, you need to use names that make sense for your variables. For instance, use "score" instead of "x".
You need to keep the code neat and tidy and you need to add comments to explain what your code does. Also, keep your functions very short and sweet.
To maintain your code, you need to use building blocks or functions that actually fit together and use clear error messages, which is like a helpful hint at all times.
