SEO Using the "alt" attribute on images
For topics specifically about improving community visibility online.
Cpvr
Community Advisor
Community Moderator
Rating - 0%
A common misconception is that the “alt” attribute is just a “TAG,” but in reality, it’s a key element that shouldn’t be overlooked.
To grasp the importance of the “alt” attribute, consider this: Google can’t actually “see” images. Instead, it processes the underlying code that helps display those images. To index and categorize your images properly, search engines rely on descriptive text. This lets them identify what your image is about, allowing it to show up in relevant searches for specific topics, people, places, or things.
If you thought the “alt” attribute was only there for showing a description when you hover over an image, it’s time to rethink that. It plays a crucial role in SEO—without it, Google won’t be able to index your image, which could affect its visibility.
That’s why it’s so important to source your own images whenever possible. And if you’re managing a forum, especially, consider finding an add-on that will automatically add the alt attribute to your
Ensuring the alt text is in place by clicking the “i” icon on an image on an Xenforo forum will make a big difference for your image SEO.
If you’re using other forum software, I’d recommend adding “alt” tags to your images as well, so you can get your images ranking on the search engines.
